1996 Ford Windstar Check Engine Light
Old 04-10-02, 07:41 AM
wgk429
Question 1996 Ford Windstar Check Engine Light
My 96 Windstars Check Engine Light came on but everything appears to be running just fine. I've heard horror stories about this being a costly problem to fix. Does anyone have any insight as to the best way to troubleshoot this? I've disconnected the battery. This works for about 4 days but then the light comes back on. I've also used premium fuel for two tankfulls and this doesn't help. Any ideas?
Thanks,
Walt
Old 04-10-02, 07:49 AM
thekeymaker
go get it diagnosed and see whats wrong disconnecting the battery will not fix if there is something wrong also there are testers you can buy but be careful when using them Don,
Old 04-10-02, 09:15 AM
Joe_F
Try Autozone. They might rent you the needed (OBDII) scanner. Find the source of the light and correct it.
