04-10-02, 09:26 AM
GENECC
91 (p.o.s)chevy lumina mini van
(p.o.s) means piece of s--t)
the problem is i have no clue about the fuel injector system. the problemis i get fuel to the carb but not to the bells(bell type fuel injection) is there a filter inside or can the it be rebuilt.
04-10-02, 09:35 AM
Joe_F
How do you know you have a fuel system problem?
Start by checking my post "The Basics".
04-10-02, 01:13 PM
GENECC
91 chevy lumina minivan
i know it the fuel injectors because the fuel gets to the carb body and back to the return but doesnt come out of the injectors.there's power going to the injectors. 1.5 motor
04-10-02, 01:16 PM
Joe_F
No 1.5 in a Lumina van.....sure you have the vehicle right?
Might not have a bad injector. Could simply be clogged.
What does your fuel pressure test reveal? What does your service manual say?
Have to start with the basics (below) or things get expensive VERY fast
04-10-02, 02:44 PM
GENECC
p.o.s
no i made a mistake the colt is a 1,5 the chevy minivan is a 3.1. no there not clogged.i already cleaned then and replaced the gaskets.
04-10-02, 05:06 PM
Joe_F
Still need to know what the fuel pressure is to know what we are dealing with here.
A bad ground can shut off the injectors and cause you to think that you do not have injector pulse.
Hook a noid light up into the fuel injector harness (any parts store has them, they are cheap). Crank the van. Tell us if the light pulses or not. If it does not, your problem is electrical, not fuel related.
04-13-02, 06:47 AM
GENECC
91 chevy lumina
i checked out everything and found that both injectord are bad is it uncommon for both to go out at the same time?
04-13-02, 09:32 AM
Joe_F
Sure. A short could wipe them both out.
What did the noid light test I told you earlier reveal?
Did you try this method?
