1993 buick la sabre
Old 04-11-02, 03:49 PM
doittoit
1993 buick la sabre
Buick with 95,000, automatic, 3800 engine (6 cy), owned it about 2 years, was "warned" by salesman "not to drive much in the mountains..& do you want computer insurance?
Problem; it stalls on average every 200-300 miles, very often with in a mile of the same daily route, @ about 6-7 miles always when slowing on down grades, then will not restart for about 15 minutes
(some times longer) twice it
has failed to start when "hot". I took it in to dealer twice no luck (honest shop, no charge, as it worked well for them). Ignition module???
Old 04-11-02, 07:17 PM
cheese's Avatar
Received 57 Votes on 52 Posts
When it quits, you must determine whether it is losing fuel, or spark, before going into it much further. Does the check engine light come on?
Old 04-12-02, 06:34 AM
doittoit
doittoit
No lights come on when or after stalling, when attempting to start all lights lite as normal engine just dies no sputtering, when attempting to start no gas fumes are noted, but the fuel injector line as pressure. So it seems the injectors are not opening, if so what contrls them? Need to know just how te system is designed to work.
Old 04-12-02, 06:46 AM
doittoit
Oops! read my post and need to correct it, None of the upper dash lights come on, those with words on them, but all of the little red lights on the instrument panel come on.
Old 04-12-02, 07:12 AM
Joe_F
Start by checking the posts and links in my signature file.
You're condemning some pretty expensive parts. They will be expensive errors! .
Old 04-12-02, 09:58 AM
doittoit
Tested a theory today drove to about the spot that car often stalls, parked and tried to start 15 minutes later NO start, till another 10 minutes (cooling time) drove it for 7 minutes parked waited 5 minutes, it started drove 6 miles parked 5 minutes, (gased up 14 gallons $18.36, have found no difference in problem with near empty or full tank) started as usual.
What I learned; heat seems to be a critical factor as engine eat seemed to have soakd in to the presumpive problem, however when car gets warmer the problem seems to go away...?
Old 04-12-02, 11:25 AM
Joe_F
Still need to start with the basics first.
You've got some good reading material in my signature file
