automotive
Old 04-14-02, 06:28 PM
D
dewittk
automotive
I have a 7000 lb.floor jack that won,t lift any weight. It goes up but if it hits resistance it stops. I donot have the book or any instructions for it, how do I add oil or check the seals, or what could be the problem.
Old 04-14-02, 08:37 PM
Joe_F
It likely has a weak piston or hydraulic ram. Any place that services hydraulics for industrial machines like forklifts can probably repair it.
I was given an old Walker jack that I will eventually have to take a crack at fixing. Too nice and heavy duty to pitch.
Old 04-14-02, 10:05 PM
B
Billdo49er
You may get it to work with a fillup.
There should be an allen screw or a square headed bolt near the top of the piston housing.
Remove it and fill with hydraulic fluid.
If it doesn't work then do as Joe F states and have it looked at.(the seals may be shot)
