fan belt
Old 04-15-02, 08:30 AM
joann toft
fan belt
can you tell me how to put a fan belt on a 1993 dodge caravan
on a 3.3 engine please
Old 04-15-02, 09:39 AM
Joe_F
Generally, there is a tensioner that holds tension on the belt.
There is usually a slot for a rachet head or you put a wrench on that bolt.
Rotate the tensioner to remove the tension on the belt. Remove the belt. Note how it is routed or refer to the underhood diagram for the routing.
Place the new belt on, lift the tensioner up and release it onto the belt. Done.
Check the links in my signature file below for more ideas.
