Nissan Pathfinder Clutch replacement
Old 04-15-02, 09:51 AM
I
images2646
Question Nissan Pathfinder Clutch replacement
I am having a problem with the removal of the two suspension rods under my 1987 Nissan Pathfinder. I have everything else off and can't finish transmission removal until I remove the suspension rods. I could use some advise or an illistration to guide me. Thanks.
Old 04-15-02, 09:53 AM
Joe_F
Whoa Nelley. Shouldn't tackle this without a Nissan shop manual...
That being said, check the link in my signature file for some ideas first. If that fails, time for an Alldata.com subscription or a factory service manual for some ideas.
Old 04-15-02, 10:00 AM
I
images2646
Thanks, I bought a manuel and it doesn't tell me
I bought a manuel on the Pathfinder, it doesn't go into enough detail. It is a 1987 Nissan Pathfinder, 4x4, 6 cylinder, manuel 5 speed, I have already dropped everything off except the two rods, attached to the rear and front.
Old 04-15-02, 10:02 AM
Joe_F
Which manual did you buy? Probably not the FACTORY one . That is the best and most detailed one for the truck. I highly suggest it. It's worth the money.
If not, a subscription to Alldata.com should provide some of what you need.
Barring that, the links in my signature file might help too.
