A/c Not Cold
Old 04-17-02, 08:19 PM
T
A/c Not Cold
Air Conditioning Not Cold
I had freon (sp?) put in last year and a/c was very cold. I've turned on the a/c a couple times this past week and it's 'okay', but not cold.
Also, I noticed when I used the heater over winter the temperature gauge sometimes went a little above the halfway mark. Would any of this have to do with the thermostat?
My radiator is about 2 yrs old, it has antifreeze, new fuel pump, alternator and head gaskets.
Please advise what I should do. This is a 96 Olds Achieva.
Thanks for all your help!
I RECEIVED SOME REPLIES ASKING ME WHY THE FREON PUT IN> HAVE HAD SEVERAL REPAIRS....INCLUDING A NEW RADIATOR AND A NEW WATER & FUEL PUMP. I'M GUESSING IT WENT ALONG WITH ONE OF THESE WHEN I LOST MY COOLANT, ETC. ANY SUGGESTIONS AS TO WHY IT MAY NOT BE COLD? NO LEAK THAT I CAN SEE. JUST HAD NEW HEAD GASKETS PUT ON A COUPLE MONTHS AGO....WOULD THAT HAVE ANYTHING TO DO WITH IT?
THANKS AGAIN FOR ALL YOU INPUT!!
Old 04-18-02, 05:47 AM
Joe_F
Back to the shop that "added" the freon last year to find out what the problem is. It may not have been charged correctly or there is still a leak in the system.
That being said, please keep all posts on the same car together for clarity. You'll lose continuity and get a slower reply from us if you split your posts.
