Brake problems-GEO Tracker
BigZ's Avatar
04-18-02, 03:17 PM   #1
BigZ
93 Tracker, brakes suddenly apply by themselves while driving. Have had pads and master cylinder replaced, changed break lines and callipers, still happening.
Help!
Passenger side front breaks seem to be locking up. Guessing this as there is break dust on the rim.
Mechanic has vehicle, is driving around daily waiting for lock-up to occur as he has no idea what the problem could be.
Joe_F's Avatar
04-18-02, 05:17 PM   #2
Joe_F
Check the pedal pushrod for binding and issues.
If one rim has more dust than the others, the problem is likely in that part of the brake circuit.
Did you change both flexible lines to each caliper and THOROUGHLY flush/bleed out the wiped out fluid? If you didn't the problem is still therel.
