'95 Ford F-150 firing order
Old 04-18-02, 05:20 PM
jamngatr
Unhappy '95 Ford F-150 firing order
Been looking fer days on net for a site that can give me the firing order or sequence of plug wires for this vehicle. Does someone know how to find this or can you tell me what this is? It is a "straight 6" engine so why can't I find this info?
Please Help!!
Old 04-18-02, 05:24 PM
Joe_F
Check the links in my signature file below for some ideas first.
Barring that, time for a service manual for the firing order. The order is printed on the mainfold. The cylinder numbers are likely stamped on the head.
Find #1 on the cap and then note which way the distributior turns. Then follow the order printed on the manifold to get them all right.
Old 04-18-02, 06:19 PM
B
1,5,3,6,2,4
Old 04-20-02, 09:53 AM
jamngatr
Thumbs up '95 Ford F-150 "On da road agin!!"
Thankx JoeCool!! With your link to autolibrary.org and your prompt response I was successful!! I did try to do one wire at a time when replacing the old, but in the process, snapped off one of the old wires, moved on to the next. That's where I messed up and had the firing order wrong. With your help, I'm good to go!! Again Thankx.
Old 04-20-02, 01:24 PM
Joe_F
Thumbs up
Not a problem. Glad it helped.
