Torque Spec
Old 04-20-02, 02:46 PM
B
Question Torque Spec
Hi all,
Does anyone know what the torque spec's are for the flywheel bolts on a 93 ford probe 2.5L V6 5 speed?
Old 04-20-02, 03:10 PM
Billdo49er
Old 04-20-02, 03:14 PM
B
That site doesn't work for me anymore. Is there something wrong with the site? Or is there anywhere else i could look?
Old 04-20-02, 03:24 PM
Billdo49er
I just tried your vehicle and had no problem.
The torque spec is 45-49ft.lbs.
Old 04-21-02, 08:14 AM
B
Pressure plate to flywheel
Could anyone help me with the torque specs for the Pressure plate to flywheel bolts. I still can not access the autolibrary.org site.
Old 04-21-02, 06:44 PM
Billdo49er
Read the previous post.
I already gave you the spec.
Old 04-21-02, 07:47 PM
B
I'm confused
The previous post I asked for the Flywheel bolts specifications. I assumed when you replied that the flywheel bolt spec, it was 45-49ft.lbs. The next question was the pressure plate bolts to flywheel. Now I'm confused. Which is the 45-49ft.lbs. spec for? And what is the other spec if you would be so kind.
