Check engine light
Old 04-20-02, 03:59 PM
wingplow
Check engine light
I have a 1997 Plymouth Voyager with a 3.3 motor, automatic transmission with 110,000 miles on it. I did a tune up and changed the transmission fluid and filter.
Now the check engine light is on. Can anyone tell me what the problem might be. How can I get the check engine light to go out.
Thanks for your help.
Old 04-20-02, 04:01 PM
Joe_F
You need an OBDII compliant scanner/code reader to see what is turning the light on.
Go to Autozone and they should be able to rent you one. Then run a code check to see why the light is on.
Old 04-20-02, 11:47 PM
Billdo49er
You may also want to purchase a scanner.
You don't need a $4,000 Snap On.
They are anywhere from $40 To $200 for the do it yourselfer.
They are just code readers which is why they are inexpensive.If you need one with a snap shot mode or pc link or test procedures then it'll cost you a few thousand.
