Ford Festiva won't start
Old 04-23-02, 02:45 PM
N
NOVASS
After operating fine since new, my 88 Ford Festiva with four-speed transmission refuses to start now.
It behaves as if the clutch is not being depressed when I try to start it (everything electric comes on and works, but it will not crank or even 'click').
I suspect the neutral safety switch, but I don't know where it is located. Can you help me to locate it?
Old 04-23-02, 02:47 PM
T
It's usually located in top of the clutch pedal. You can disconect it, then use a short wire to simulate a pushed down clutch. If the car starts, then you've found your problem. Replacing it should be simple.
