89 Ford Tempo
Old 04-23-02, 09:16 PM
tequilastr82
89 Ford Tempo
Hi
my son bought his first car a 89 ford tempo,the horn does not work.he cannot find it could you help??? need to find the location thank you in advance for your help
Old 04-24-02, 04:43 AM
the_tow_guy's Avatar
Received 259 Upvotes on 210 Posts
No doubt Joe will come along with the exact loaction, but try under the fenders, left side I think. Should be able to see it through access/wiring holes inside engine compartment.
Old 04-24-02, 06:31 AM
Joe_F
See the links in my signature file for some ideas.
TowGuy is likely right. Locate the horns. Bring power directly to the horns. If they sound, the horns are fine. The problem is the contact in the steering wheel, the wiring, or a bad horn relay.
Can you hear a click when you tap the horn? Have you checked the fuse?
