Hatch Lifter on 95 Nissan Pathfinder
Old 04-24-02, 02:02 PM
joeybergeron
Has anyone ever changed the factory hatch lifters on a 95 Nissan Pathfinder or similar SUV? The package says there is a secure ring around the ball and socket that holds the lifter to the hatch, however I do not see it. Do you unscrew the ball from the hatch itself?
Thanks,
Joey
Old 04-24-02, 04:03 PM
chadtoolio
There is a ring that slides over the ball socket of the strut to hold it in place. If you take a small screwdriver or pick, you can slide to the side and remove the strut. Look at your new ones, you maybe able to see it better...
Good luck
