98 Chevy Astro
Old 04-27-02, 06:35 PM
Charles E.
98 Chevy Astro
Got a wierd problem. The power windows work sometimes and sometimes they don't. Doesn't seem to be any perticular time but when it does left and right windows will not roll up or down. Been caught out in the rain several times. Never at home, so I can put a tester to check for power. Are these windows powered by a fuse or a breaker? Any help will be much appreciated. Thanks Charles
Old 04-27-02, 06:51 PM
knuckles
I'm going to assume the power window switch is door-mounted on the '98 Astro as it was on the older models. If that's the case, peel back the rubber boot between the van body & driver's door & inspect for broken wires. It's very common & causes a bunch of intermittent electrical problems.
Old 04-27-02, 07:15 PM
Charles E.
Knuckles You are exactly right the controls are mounted on the doors. Thanks! i'll check it out tomorrow. I get back to you with the results. Thanks again Charles
