replacing a starter
Old 04-27-02, 08:06 PM
Effrice
replacing a starter
i have a 1995 chevy montecarlo. i am trying to replace the
starter, however i cannot get the starter to come out. there is
not enough clearence, not sure what to do next.
Old 04-27-02, 08:33 PM
knuckles
Question
Engine size?
There's plenty of room on the 3.1 & 3.4 OHV engines. The 3.4 Twin Dual Cam engine is a different story.
Old 04-28-02, 02:07 PM
olehippieinsc
replacing starter
Had the same problem with a 1993 Chevy/Lumina. Had to
remove the nuts from the 2 bolts on the front motor mount bracket that
pass through the frame just behind the crank shaft pulley. Then
used a piece of 2x4 and a bottle jack to raise front of engine up
about 2 inches. That gave me enough clearance to get the
starter out. Hope this helps.
