93 Buick Park Ave. Sideview Mirror
Old 05-01-02, 07:26 AM
W
weekendwrencher
Question 93 Buick Park Ave. Sideview Mirror
I'm attempting to replace the driver side power mirror on my 93 Park Ave. How do I get at this thing? Do I have to completely remove the inner door panel to get at the two threaded studs that hold the mirror on?? Is there any trick to removing the inner panel if that's what I have to do? Thanks for your help.
Old 05-01-02, 08:53 AM
Joe_F
Yup, the door panel comes off. I did it on my uncles 1992 LeSabre. The door panel comes off and then you use a 13mm socket on a swivel/extension to remove the two bolts that hold the mirror to the door. It's a bit tight up there. Might have to use a wrench to loosen the nuts.
You can probably get a schematic of the door panel removal from the www.autolibrary.org link in my signature file below.
