dodge shadow allmost dies but doesnt
i have a 1994 dodge shadow2.2 auto and it will intermittantly act as if it si going to conk out( ie cough/sneez) then come back to life well allmost it will have a problem with getting up to the speed limit it coughs spuddersbut doesnt conk out ,just had a tune up done on it( spark plugs,oil,fuel injectors cleaned.engin temp is normal outside temp is 85-90 deg / it allso has a problem with overheating when it is running but not moving not moving
I had a similar problem on my dodge shadow 94
something got stuck in the cooling fan, removed it that fixed the problem.
You are certain it is the 2.2L and not the 2.5L? I think the 2.2 has carb/mechanical fuel pump and the 2.5 has throttle body and fuel pump in gas tank. The reason I ask is that this could make a difference as far as the behavior of how your car is getting gas and associated problems.
If car only overheats while parked but not at highwway speeds, means your fan is not coming on at all or when it should, most likely. It shows the radiator/circulation is okay because of the fact it can cool down with the highway wind blowing through the radiator. Do not neglect overheating on these cars. Easy to blow headgaskets in these little Dodges.
