85 pajero
85 pajero
need detailed info on removal of alternator in 85 mitsubishi 4wd. main mounting bolt is not a normal nut its round with flat edges either side,sockets don't fit, is there special tooling required?
We do not get the Pajero here in the States. That is an export model. I believe it is the same as a Montero if my memory serves me right. It's some sort of SUV thing.
You can try the links in my signature file for some ideas for a similar model Mitsubishi that did get exported here and see if that helps.
Otherwise, I recommend calling Mitsubishi for the specific Pajero service manual for the thing. There are likely to be differences between it and the corresponding model that did come here to the States.
