transfer case and transmission
I have a 1979 suburban with full-time four wheel drive (L, L LOC, H, H LOC). Manual says refill transfer case with 10W-30 but I have aftermarket manual hubs. So, is it really full-time or should I use 80W that's recommended for conventional four wheel drive? Also, when I drain the automatic transmission, how many quarts to refill? 10?
You have a NP 203 transfer case. The fact that it has been converted to part time 4WD has no bearing on its lubrication requirements. 10W30 is the factory recommended lube & that's what you should use unless this truck sees extreme conditions such as mud bogging on a regular basis. The mud boggers use SAE 40 & report no problems.
Drain & refill specs vary depending on trans & convertor combination. Drain the trans, change the filter & install the pan.
Add 4 quarts of ATF & start the engine. Check the ATF level. Add in 1 qt. increments until the fluid is just below the hash marks on the dipstick with the engine at a hot idle. Add .5 qt. & recheck. The fluid should now be roughly in the middle of the hash marks, which is perfect. Make a note of the amount of ATF you used for future reference.
Thanks to all! There was a little residue in the pan but I understand that's normal wear and tear. I also noticed a couple of shavings. Other than that the tranny seems ok. Any tips on maintenance of the axles and transfer case since that will be my next project? Also, it shimmys sometimes as if the wheels are out of balance but sometimes the ride is smooth at the same speed. Is it the stabilizer or ?
