bad head gasket
bad head gasket
I've removed the cylinder head from my car, and it is not apparent to me where the leak is coming from. I've never done this before, so should it be obvious? I know the coolant was getting in the crankcase for sure, so there is a leak. thanks.
Israel
Israel
Well at first there was a tremor, which could be felt when stopped at a red light. I thought it was the spark plugs. I have been having some coolant problems: the heater core is partially blocked, and the car was running a little hotter than usual, I also noticed that I kept filling up the coolant and it going below level. Then a little white smoke started coming out, and then the tremors got really bad and a lot of white smoke started coming out. I shut down the car and haven't started it up since. The crankcase oil was fouled with water, so I figured it was either the head gasket or a crack in the block. what do you think?
Israel
Israel
I agree with your diagnosis on the head gasket. That is most likely the problem. A crack in one of the heads could also be the problem. A crack in the block...almost never. If the gasket isn't blown, you may find the fault in one of the heads, but you won't likely see it upon visual inspection.
The head could crack without blowing the gasket, but once you removed it, it probably warped. I see by your previous questions in other threads that this is a dodge 2.5 engine. You should have no problem finding a good used head for it if it does turn out to be cracked. There's no good way to repair a cracked head...replace it. A machine shop can easily check it for a few bucks. Have the replacement head checked before installing it too if it's used.
