bad clutch or tranny????
I have a 93 honda accord LX. When idle or driving it make a pinging noise, but when idle and you press on the clutch it goes away. The clutch is 4 months old. Someone says it is the tranny another says it is the bearrings in the clutch. When I was driving it would slip out of 5th gear so I would drive in 4th. Then 4th wouldnt work at all. When I was driving it sounded as if something feel. I now had no gears. But it moves if you give it alot of gas and drive slowly but after a while it starts to jump. Please tell me some good news!!!!!!!
Sound like the trans is bad and need to be pulled. With the trans out you can check the clucth out at same time. The way to test for noise is to put trans in gear and push the clucth pedal in, at this time nothing in the trans is turning and all is still. if it makes noise at this time you know it is not the trans. if you put it in neut. and release the clucth pedal and it makes noise it is in trans. If you replace the clucth assy ALWAYS replace pilot bushing are bearing and throw out bearing at same time. Good luck-----Dave.
But one more thing, when I did have a bad clutch I would drive and the rpms would go real high(slippage) So now that problem isnt happening. I know a little about cars and I really dont think it is the clutch. I may be wrong. Is it worth fixing the throw out bearring with the possible bad 4th and 5th gear sinks.
