Starter replacement
Starter replacement
Got a '93 s10 w/4.3 It had a bad starter selonoid, opon removal we found the starter was under warrany thru a local parts store.
What came in the box was a new starter (not rebuilt) for whatever reason. After installation, no movement from the starter at all!!??
Do you think I did something wrong? theres a lot of stuff to take off. Then ofcourse the wiggling to get it out.
Thanks
Thanks
Did you install it correctly?
Your original starter had only 2 terminals. The large terminal is the BATT terminal & the small "S" or Start terminal.
Most replacement starters (including many AC Delco Remans) come with a 3 terminal solenoid. The 3rd terminal is usually labeled "I" or "R" (for Ignition or Resistor bypass).
The starter won't work if you attach your "start" wire to the "I" or "R" terminal.
