1988 camry- runs ruff after rain
Old 05-09-02, 01:18 PM
dawgpound
have a problem with the car running ruff mainly after a rain.
have changed plug wires and distributer cap several time but problem still there. after a while she will run fine.
can it be drawing moiture somewhere else to make it run bad?
Old 05-09-02, 04:05 PM
wilm105
Ruff Idle after rain
Hello;
I have owned more than a half dozen of that body style and learned the hard way that you have to use a Toyota set of wires and cap (both come as a set). My machines seem to always run better in the rain.....I have also replaced a coil which is located under the cap. I would also check the air filter, since your already there and use a good injector cleaner like Techron. I hope this gave you a few ideas.....change the oil and it will last for over 200K miles.
Good Luck!
Trackbacks are On
Pingbacks are On
Refbacks are On
