94 beretta
Old 05-10-02, 01:18 PM
The one
94 beretta
replaced flasher and hazards work just no turn signal's.This has really got me stumped
Old 05-10-02, 01:27 PM
Joe_F
Keep all posts together by using your reply button.
Likely a bad ground at this point. Again, do the hazard flashers work correctly?
You may have changed the HAZARD flasher and not the turn signal flasher. Most vehicles have two.
Most times they are in the fuse box or next to the steering column. A quick call to any GM dealer's parts dept. should net you the location.
I'd bet you changed the wrong flasher.
Old 01-31-08, 01:13 PM
C
had that problem before it was the turn signal switch...
Old 01-31-08, 03:33 PM
the_tow_guy's Avatar
Received 184 Upvotes on 146 Posts
Dude, this is a 5 1/2 year old thread.
