chnging watr pump on 84 s10 pu
Old 05-11-02, 08:29 PM
Stanb
Please advise how I can remove the fan stud bolts from the old water pump. Thanks.
Old 05-11-02, 09:08 PM
Joe_F
Studs usually come with new or reman water pumps, so don't save 'em.
If you have to get them out, I use a vice grip and just twist 'em out.
If you booger them up, I believe the studs are available as a separate item.
Old 05-12-02, 07:55 AM
Stanb
I removed the studs by installing one nut and while holding it with and end wrench tightening a second nut against it. Then I used the end wrench and the first nut to back the stud out. Thanks very much for replying.
