Stuck Window
Old 05-13-02, 02:58 PM
greenm&m
Unhappy Stuck Window
I have a Toyota Camry and the passenger power window (once it has been let down) will not go up, except a little at a time over SEVERAL days. It's the rainy season and I need a quick fix or need to know what type of shop to take it to for repair. Thanks
Old 05-13-02, 08:22 PM
Joe_F
Year?
Check the switches for corrosion. Barring that, take the door panel off. Bring power to the motor. If it always works well, bad wiring, switch or connection. If bringing power to the motor still makes it erratic in operation, bad motor. Common problem.
A bit of a gazorch on a Camry to service.
Old 05-13-02, 11:10 PM
merlo
It could also be the window regulator. Some Toyotas have a cable regulator assembly, and often the cable gets twisted or broken, preventing the window from working. You will need to remove the door panel to check the motor and regulator. An auto glass shop should be able to help you.
