Key stuck in ignition!
Old 05-13-02, 08:49 PM
razzberry1031
Hyndai (honday)
Excel
1993
4 cylinder
My mom's key is stuck in the ignition. One day it just wouldn't come out. Until they took out her battery, and then it came out.
She has to take out the battery now, to remove the key. The battery needs recharged every 3 day's. Everytime she uses the car, she disconnects the battery.
Old 05-14-02, 03:43 AM
Joe_F
If disconnecting the battery allows the key to be removed, then you might have a faulty switch.
If the battery dies every 3 days, you have a drain. Hook up a test light inbetween the battery and the same terminal. The light will glow brightly.
Pull the fuses one by one. The one that really dims the light is the problem circuit. Start there.
Old 05-14-02, 10:52 AM
razzberry1031
Talking Re: My key is stuck in the ignition! Thank again Joe_F!
Thank you so much Joe!
Trackbacks are On
Pingbacks are On
Refbacks are On
