A/c
A/c
The air conditioner clutch will not engage. Do I need to replace the compressor, or is there anything I should check?
Low pressure cut off switch.
Find your low pressure cut off switch. Unplug the 2 wire plug and shunt it to by pass the switch. If you are just low on coolant the compressor will engage & run. If not start running down your power and check your fuses. At least the shunt trick may save you some work.
