A/c
e1b1c1's Avatar
05-14-02, 07:36 PM   #1
e1b1c1
A/c
The air conditioner clutch will not engage. Do I need to replace the compressor, or is there anything I should check?
otter_'s Avatar
05-14-02, 07:45 PM   #2
otter_
could be
low / no refrigerant. There is a low pressure switch which will not let the compressor engage in such circumstances.
marturo's Avatar
05-14-02, 08:53 PM   #3
Low pressure cut off switch.
Find your low pressure cut off switch. Unplug the 2 wire plug and shunt it to by pass the switch. If you are just low on coolant the compressor will engage & run. If not start running down your power and check your fuses. At least the shunt trick may save you some work.
