Timing Chain
Old 05-16-02, 07:48 AM
rickv
Unhappy Timing Chain
I have a 1995 Tahoe that turns over very quickly, and will not start. It seems to me that it is the timing chain, or the gear. How would I be able to determine this? Are there any other possible problems that I should consider? The truck has 132,000 miles and I was told that it is probably not the timing gear because they switched to steel gears before 1995. Any suggestions?
rickv
Old 05-16-02, 08:33 AM
Joe_F
Does the distributor rotor turn?
Start with my post "The Basics" below and the links below and tell us what you find.
