brown discoloration on block
Old 05-16-02, 03:02 PM
firstshift
Folks:
96 Corolla, 1.8 L
I have noticed brown discoloration on block, appears to stem from uper rad. hose. Reverse flushed raidiator and coolant was, of course, same color, now it's a healthy green again. Have been adding more coolant than normal, about 2 qts a month. Do I have a leaking head gasket? Is it time for a pressure check?
Thanks,
Firstshift
Old 05-16-02, 03:34 PM
Joe_F
You may have had a leaking hose or a thermostat.
A pressure check wouldn't hurt. How long did you wait to flush the coolant?
Old 05-16-02, 07:18 PM
firstshift
Joe:
Flushed at about 60K and 128K. I'll take your advice and ge ta pressure check.
Thanks,
Firstshift
Old 05-17-02, 06:41 AM
Joe_F
Too long. Flush your coolant every year on the dot. Cheap, effective and prevents trouble.
