1992 Lumina Waterpump
Old 05-17-02, 08:39 PM
D
dale8899
How difficult is it to repair a waterpump in a Lumina
Old 05-17-02, 10:55 PM
K
knuckles
It's a cake job! 20-30 minutes tops!
1. Loosen water pump pulley bolts.
2. Remove serpentine belt.
3. Remove water pump pulley bolts.
4. Remove water pump bolts.
5. Clean mating surface.
6. Install water pump.
7. Install water pump pulley.
8. Install serpentine belt & recheck tightness of w/p pulley bolts.
9. Refill & bleed cooling system.
Ooops!.....Step 1 should have read, "drain cooling system".
