Water pump on a Chevy K-1500
Krystyne's Avatar
05-20-02, 09:27 AM   #1
Krystyne
Is it hard to replace a water pump on a Chevy K-1500 truck if you are doing it yourself?
Joe_F's Avatar
05-20-02, 09:30 AM   #2
Joe_F
Year? Engine size?
Krystyne's Avatar
05-20-02, 09:37 AM   #3
Krystyne
Water Pump
It is a 1992, 350 Liter.
Joe_F's Avatar
05-20-02, 09:40 AM   #4
Joe_F
No, generally not hard at all.
Suggest you pick up a repair manual for it (any parts store or try the local library). That being said, you can also look at the www.autolibrary.org link in my signature file below.
Krystyne's Avatar
05-20-02, 09:41 AM   #5
Krystyne
water pump
Thank you, I just can't see paying $61.00 for a new one and paying all the labor for someone else to do it if it is simple to do.
Krystyne's Avatar
05-20-02, 09:48 AM   #6
Krystyne
autolibrary
My vehicle is not listed in the autolibrary.org. Any other suggestions?
Joe_F's Avatar
05-20-02, 10:19 AM   #7
Joe_F
Try looking it up for a C series (2WD truck...K is 4WD). It should be the same thing, same motor.
Barring that, go to any parts store and buy a 15 dollar Haynes manual. Good investment. You can try some local libraries, they have some repair manuals too.
knuckles's Avatar
05-20-02, 11:39 PM   #8
knuckles
The autolibrary site can be difficult to navigate until you get used to its quirks. Your truck is listed. Click here for autolibrary.org's water pump R&R procedure.
dirty dan's Avatar
LA
05-21-02, 12:05 AM   #9
Pay attention when doing your work. Many of the K's are mad ein Canada and have a mixture of SAE and metric bolts. GM seems fond of 15mm. Be careful not to round off bolt heads with the wrong tool. Job should take less than 2 hours for a novice with a manual. Be sure to clean your gasket surfaces well.
Krystyne's Avatar
05-21-02, 05:58 AM   #10
Krystyne
Thank you for all your help....couldn't bring myself to paying for someone else to do it for a $25.00 part, as we all seem to do time and time again. I was told that if the person who is going to be doing it has put in a starter, an altenator and a radiator, that he should be able to put in a water pump.
