94 GMC Sonoma 4x4 W/ABS : Bleeding Brakes
HI ,Wondering if there is anything out of the ordinary to do when bleeding brakes on this ABS system. Has had fairly low pedal, after replacing front pads and rear shoes still not the best feel on pedal. Think i can get bleers loose... any tips? Thanks, LC
Thanks for your reply, I have tried to bleed brakes as usual manual method. Still the pedal is very low and feels soft. It does have braking ability. I am concered that the ABS system needs to be bled. This is a 1994 GMC Sonoma and I think was the first year with ABS. I think I need instructions to bleed this particular system. If you think of something else let me know. Thanks again,Larry
