Vibration
Old 05-27-02, 12:50 PM
blshakers
Question Vibration
I have a 94 Fiord Explorer, I have a vibration at 63mph. I have replaced the tires,universal joints,rotors,brakes,drums,torque converter etc, The front end looks solid. Any Ideas?
Old 05-27-02, 03:36 PM
Joe_F
Check www.alldata.com for known bulletins on this problem. Motor mounts come to mind as a possible problem here.
Make sure a driveshaft weight has not come off or you will get a vibration. Have the rims balanced again to be sure a weight hasn't fallen off. Rotate the tires front to back to see if the problem transfers to the back now.
You cannot tell the front end "looks" solid. It has to be checked for wear and looseness.
