Saturn Oil Change Light
Old 05-27-02, 01:35 PM
My girlfriend got an oil change on her 2002 Saturn SL2 1.9 at 2200 miles. Her car recently hit 3,000. Now one of the idiot lights is on reading "Change Oil Soon". I heard this is part of the GM Oil Life System. Does anyone know how I can go about reseting this light? Thanks.
Old 05-27-02, 02:24 PM
Joe_F
What does the owner's manual have to say about it?
Old 05-27-02, 06:27 PM
otter_
sounds like
whomever changed the oil didn't bother to reset the light. Look in the index of your owners manual under "engine oil life monitor".
You can also try a shortcut available in most GM product:
1. Turn ignition to "run", DO NOT START ENGINE
2. Depress and release accelerator 3 times
Oil light should flash a couple of times, then extinguish.
If the above doesn't work, read your owner's manual.
Old 05-27-02, 07:13 PM
Figured it out. You turn the key to ON, pop the hood and in the fuse box on the drivers side is a reset button. Press it, the light flashes, and you're all set. Pretty stupid system if you ask me. But thats just my opinion.
