Transmission
Old 05-27-02, 09:01 PM
hicap
Transmission
1990 Dodge Dakota 4WD , 5 -spd manual tranny, with 159,000 miles. Only engages in 4th gear. Have lost ability to shift into and use all other gears. New clutch installed 20,000 mi. ago after throwout bearing disintegrated...Where do I look?....Transfer Case/Tranny/Clutch?
Old 05-27-02, 09:52 PM
storminnorman
does that include neutral, when you let off clutch is it in fourth? and you can not move the shifter to any other gear? if so probably input shaft (4th) gear seized into output shaft, bearing failure, if that is the case i would suggest trying salvage yard for another unit.
