cruise control non-functioning on used 1994 Ford aerostar
jmellske's Avatar
05-29-02, 04:28 AM   #1
jmellske
2-wd xlt model 1994 Ford Aerostar
cruise /speed control does not operate at all
checked fuses they are okay
any ideas about suspect parts/troubleshooting?
only 40,000 miles on used vehicle invery good condition.
Thanks,
Joe
Joe_F's Avatar
05-29-02, 05:27 AM   #2
Joe_F
Check some of the links below in my signature file.
trendar's Avatar
05-29-02, 01:04 PM   #3
trendar
by any chance is the speedometer not working? On a similar transmission with the A4LD, if the speed sensor is not outputting, the speedometer and cruise won't work, since the cruise control is not enabled below 40mph. After replacing the speed sensor about 66 from AZ, both worked again.
otter_'s Avatar
05-29-02, 07:48 PM   #4
otter_
check for a disconnected
cracked or split vacuum line.
