turn signals problem
Old 05-29-02, 07:09 AM
Rick Lomheim
Thanks Joe car is standard 99 Caddy Deville I know it is still under Warranty but Dealer waffling as it is just about 75000 kms.
I found flasher for hazard lights - disconnected it - hazards then dead of course. can't find flasher for turn signals. hazards flasher is simple old Wagner type used years ago! all bulbs good. all other items on car function perfectly. if I could find turn signal flasher I could check it but can't find it!! checked every fuse on car all ok thanks for help
Old 05-29-02, 08:14 AM
Joe_F
Keep all posts on the same vehicle together for clarity and conciseness by using your reply button.
A quick call to any GM dealer's parts department will get you the location of the turn signal relay/flasher.
That being said, again, should be covered by the warranty. It's a Cadillac, not a Yugo .
