ignition problems
Old 05-29-02, 07:43 PM
pchristmas
ignition problems
I have a 1989 Acura Integra. It starts perfectly fine the first time, but if I have to stop more than once in a short period of time, it will not start for at least 20 minutes. It also will not start if it is very hot outside. We have replace the oxygen sensor and the fuel filter. ANy other ideas what could be wrong?
THanks!
Old 05-29-02, 07:47 PM
Lightbulb
How many miles ? It maybe the fuel pump is going out. Good luck on the repairs. Keep me posted.
OM
Old 05-30-02, 06:42 AM
pchristmas
About 105,000. Thanks for the advice!! I will definitely check out the fuel pump.
Old 05-30-02, 06:44 AM
Joe_F
Many woes on these vintage Acuras and Hondas with bad igniters, coils, caps, etc.
When it won't start, pull off a plug wire and see if you have spark or not. If you don't the module/igniter is likely the culprit.
Check www.alldata.com for known bulletins on this problem if any.
