front end wobble '92 Blazer
boman's Avatar
06-01-02, 03:11 AM   #1
'92 Blazer shimmies/wobbles real bad when appling brakes at any substantial speed. If the rotors were causing this, would I not feel it back through the brake pedal? One guy suggested I bleed the front brakes and th emaster cylinder. I really do not know of air in the brakes ever causing this that I am aware of. The wheel bearings seem to be okay and it drives good until the brakes are applied. Thats when the thing feels like the front end is about to come apart. Suggestions?
Tx
Joe_F's Avatar
06-01-02, 05:59 AM   #2
Joe_F
You could have worn caliper bushings, but I would inspect the rotors. May not be THAT bad to cause it through the pedal, but still might be warped a bit.
