Elecrtal Problem
Old 06-01-02, 01:04 PM
JAMES PEACOCK
Angry Elecrtal Problem
NO SPARK TO SPARK PLUGS 1991 honda accord.
Old 06-01-02, 09:50 PM
monstermechanic
91 Honda No Spark
Hello
Just a few questions for you
Is there voltage to the coil
if so is there a pulse from the dist to the coil
is the timing belt still in one piece?
The most common solution is the timing belt
Thanks
Old 06-02-02, 08:08 AM
Joe_F
These vintage Accords are known for many ignition woes.
The cap, rotor, coil, module/ignitor have been superseded many times due to poor design and high failure.
Check the links in my signature file for some ideas on how to test them, but it's likely ignition related.
Yes, take the cap off and see if the rotor turns when you crank it as mentioned above. If not, the timing belt broke and it could be curtains for the valves if this is an interference engine.
