Powertrain control module & oxygen sensor
ladyunderthehoo's Avatar
06-01-02, 02:40 PM   #1
ladyunderthehoo
1993 Cadilliac Deville, 4.9L, automatic.
Where is the PTM (powertrain control module) located and how do I replace it? Where is the oxygen sensor located and how do I replace it? Please send help to [email protected] Thank's.
knuckles's Avatar
06-01-02, 10:42 PM   #2
knuckles
What sort of problem are you having with the car & why do you think replacing the PCM & O2 sensor will cure it?
06-02-02, 03:56 AM   #3
ladyunderthehoo
Reply to knuckles
The computer read-out showed the code for the oxygen sensor and the PCM. Also, the SSS light is on. This stands for Speed Sensitive Steering. Any ideas? Thanks for the help.
Joe_F's Avatar
06-02-02, 06:50 AM   #4
Joe_F
Again, as Knuckles stated, what problems are you having?
Changing a PCM if it's not bad is quite an expensive mistake.
The 02 sensor is a maintenance item and should be changed as a matter of course.
06-03-02, 05:29 AM   #5
ladyunderthehoo
Reply to JoeF
Thank you for your help. The car is having transmission problems and according to the mechanic, who rebuilt it twice, it is the PCM. Another mechanic (2nd Opinion) had the same answer. This mechanic also installed a circut breaker for the transmission fuse that keeps blowing out. When I bought the car (used), It had just had the transmission re-built. Four months later I started having trouble. The car lost its power and wouldn't shift properly. Took it to the trans. shop that re-built it, they installed some sort of fuse. Car ran fine for 2 months, same problem. This time the trans. has to be re-built (2 rebuilds in 6 months). Car ran fine for 2 months, happened again. I called the Cadillac dealership, they told me how to bring up the codes (in the climate control) the PCM, O2, and MAP sensor codes showed up. I replaced the MAP. Re-set the codes and the PCM and O2 showed up again.
Joe_F's Avatar
06-03-02, 06:07 AM   #6
Joe_F
Something doesn't sound right...
Make sure there are not known bulletins on your problem at www.alldata.com
Also, have the PCM tested through a parts store to determine actual fault before spending the money on one.
06-03-02, 10:56 PM   #7
ladyunderthehoo
WOW! LOTS OF BULLETINS
Went to alldata.com and found 1 safety recall, 1 emissions recall, 3 general recalls and 287 service bulletins (1-1993 to 1-2002). OK, now what do I do with them? Thank you for telling me that I could have the PCM tested. I will do that before I spend the $160 for a new one. Maybe I should start there????
Joe_F's Avatar
06-04-02, 05:54 AM   #8
Joe_F
Yup, have it tested to be sure it's bad first.
