06-02-02, 09:07 AM
tlhranch
have a 1991 ford explorer 4x4, 6 cyl i am removing tranny.
I am at transfer case have it unbolted but it will not pull back out !!
is their a secert to pull it out???????
rechecked everything and nothing connected to it, just wont come back to be removed??
thanks
tlh ranch
thanks
tlh ranch
06-02-02, 11:49 AM
No secret that i know of.Make sure you have all those bolts out though.There should be one on the bottom that you can't even remove unless you remove the transmission mount(Fords better ideas).Also you usually have to pry the case free due to the silicone/gasket used to hold it.
06-03-02, 05:49 AM
tlhranch
has 5 bolts pattern
thanks i am having a hand try prying it out, just seems hooked on something.
tlh ranch
tlh ranch
