1990 Olds Cutlass Supreme SL- Door Panel Removal,Power Window Motor & Switch Replace
I would like to know how to remove the drivers and passenger side door panels. I need to replace the power window motor & operator switch modules.
I just got done doing that exact job! It is not to tough of a job. The main thing is to take your time and pay attention to the small details. First, get some of the white plastic door panel things that secure the panel to the door itself. It is just a good idea to have some on hand. Remember that there is a screw that secures the door pull at the top of the pull itself. Trust me, you will find it! After you remove the panel you probably are going to have to drill out some pop rivets. 3/16 is the size. Everything else just requires a little patience and common sense. I hope this helps you
