Power Steering - desparate
Tink2012's Avatar
06-03-02, 11:48 AM   #1
Tink2012
I have a 1999 Ford Taurus. The power steering pump started whining and I added fluid. Now it shoots fluid out of the top and then I can't steer. Help!!!
Joe_F's Avatar
06-03-02, 12:42 PM   #2
Joe_F
Is it full? Now overfilled?
Take some out with a turkey baster and then refill it to the right level.
Start it up and see if it's ok now.
fordtech's Avatar
06-04-02, 07:13 PM   #3
I could almost bet you that if you look at the powersteering line as it comes off the powersteering pump you'll see what looks like a ball made into the line.The thing mentioned is supposed to help
quite the system.These things are extremely hard to bleed of air(usually have to use a motorized vacuum pump to do so) and costly to repair if not fixed before the pump burns up.
I'd have to suggest the dealer on this one.
Tink2012's Avatar
06-08-02, 05:20 PM   #4
Tink2012
more power steering
My well-meaning husband tried the turkey baster, however he used F-type transmission fluid in the power steering pump and now it no longer whines but all I have is "muscle power". I can't convince him that the fluids are different. He says that one is just more expensive.
How bad can it be.
I also have a problem locating a pump if I need to replace it. I have conflicting information. One place says"special order", one says "in stock-with or without reservoir", one says "same pump from '92-'99" and one says none of them know what they are talking about.
Please clarify this also.
More info...
1999 Taurus LX, 3.0 Vulcan, SOHC.
