overheating eclipse
eclipse_man92's Avatar
06-03-02, 01:13 PM   #1
eclipse_man92
overheating eclipse
I have a 92 Mitsubishi Eclipse(1.8L, non turbo, DOHC). It keeps overheating. The fans work. I'm not sure when the last coolant system servicing was. I'm pretty sure the water pump is working. I have replaced the thermostat. I get white smoke out of the tail pipe every now and then.
Joe_F's Avatar
06-04-02, 05:53 AM   #2
Joe_F
If the white smoke is sweet smelling, you have a blown head gasket or a warped/cracked head.
Any shop can check for the presence of hydrocarbons in the coolant, which indicates a blown gasket/cracked head.
