90 Honda Prelude
wingplow's Avatar
06-04-02, 06:24 AM   #1
wingplow
90 Honda Prelude
I have a 1990 Honda Prelude with a 2.0 engine. Number 2 cylinder not firing. We took a compression test (125 lbs). No aigns of a bad head gasket. No signs of antifreeze in the oil. Could it be bad valves. Any help on this matter will be greatly appreceated.
Thanks
tinman1's Avatar
06-04-02, 09:09 PM   #2
tinman1
If you have good compression the valves should be ok. Check for a bad plug wire or bad plug or coil/ distributor
wingplow's Avatar
06-05-02, 05:34 AM   #3
wingplow
1990 Honda Prelude
We put new plugs, wires, cap, and rotor. Still not firing. Going to pull the head and have it checked out . Will post back any problems we find.
Thanks
