Honda engine
Old 06-04-02, 06:37 AM
wingplow
Honda engine
Does anyone know if the Honda 1990 engine (2.0) is a interference engine. What I mean is if the timing belt breaks will the valves go though the piston.
Thanks
Old 06-04-02, 06:53 AM
It is interference....and the second answer depends on the RPMs...
Old 06-05-02, 05:46 AM
the_tow_guy's Avatar
Most Hondas are. Generally all they do is bend the valves (as if that's not enough!) One of the easiest "no-start"s to diagnose because of the distinctive sound while cranking. And for your NEXT question, probably $800-1200 depending on your location and what it needs.
Old 06-05-02, 07:21 AM
Joe_F
Congrats . According to the Gates lookup, this is an interference engine. Good chance if the belt broke in operation, the valves are bent. Another Honda "exclusive"
(Yea, I know TowGuy is shaking his head that I say I don't have these problems on my rear drivers...but this is one case that I'm glad I own old American iron ).
What did your compression check show? Does the ignition rotor now turn when you crank? If not, broken timing belt.
At the same time you do the repair, change the water pump or else you'll do it again .
These Preludes start to soak you bad as they get older . Eeeek.
Old 06-05-02, 08:08 AM
wingplow
1990 Honda Prelude
The timing belt did not break. The car runs but does not fire on the # 2 cylinder. The compression test on #2 cylinder Shows 125lbs and leaks down slow. We did try new plugs wires cap and rotor first but that did not help. There are no signs of anti freeze in the oil. The car was running fine before this happened.
Thanks
